ProtonPozer
Hey guys! I feel like I am retelling my story each time, but in case you didn't scan my others, here is my abbreviated story: I have a 2008 Bravo EVT 4000e Scooter.
I recently started a project to replace the controller without first fully understanding how the original arrangement operated. The new controller seems to work in the "Learn mode" (short circuiting the two white wires), but there is no throttle response. (I ordered a cheap Hall Effects throttle and will try that as a fix.
I am not certain that the original throttle Unit on my scooter is a Hall Sensor type. To me it resembles a 3-wire rheostat.
I am pretty sure that the new (after-market) controller is looking for a Hall Effects Sensor from the throttle.
And maybe I am wrong and would not mind being corrected by others with vastly more experience.
I tested the existing throttle assembly. Between the BLACK and the GREY wires (throttle side) there is a range in resistance from 1.25KOhms to 9.17KOhms, from zero to full throttle and no reading from the ORANGE wire.
For the sake of conversation, if I tried to connect the old throttle with the 3-wires on the new controller, please make an educated guess as to which color should attach to which. (See my rough sketch).
Thanks!
Thanks!
