Hi all,
I've been trying to get my old cargo bike back on the road. The display got rained on and stopped working 2+ years ago. Today I just started alligator clipping V+ (I assumed 5V, but it was battery voltage, 39V) to various pins, and I now have the throttle working, so the controller is still good, or at least not totally bad (I rode it and it accelerates as normal for full power, full throttle). Now I'd like to get the Peddle Assist System working again.
The display has 6 wires labelled
TX (grn), RX (blu), DD (yel), DS (whi), G (blk), and V+ (red).
I used an alligator clip to short V+ and DS. Like this, the throttle works, and accelerates the bike. PAS doesn't. It's also full power; I used to use either 2/5 or 3/5 bars of power setting as otherwise I go too fast on the local biking/walking path.
The s890 display is not the same as shows up on ebay by that name. It was used on the Biruni Scarlett ebike, as seen here:
electricbikereview.com
and here:
There are also 4 wires coming from a separate 3 button module
GND (blk), UP (grn), DOWN (blu) , SET (yel)
Would a controller like this one get my PAS system working, and with some choice of power level?:
That shows 6 pins, and UART. How do I figure out if I need a UART or KT controller, or one with some other protocol?
In my attached photos, the black box is the unlabelled motor controller, the other two show the inside of the display/3 button module.
Biruni Scarlett Review
Price: $2499 | Model Year: 2014 | Custom designed light weight electric cargo bike with unique asymmetrical step-through frame Powerful 500 watt high torque gearless direct drive rear hub motor is quiet, smooth and tough Front and rear racks, built directly from frame tubing offer plenty of...
and here:
6PIN S810 E-Bike Meter LED Display IP65 36V UART for Electric Bike Electric4276 | eBay
IP65 waterproof grade. Applicable handlebar: 22.2mm.
www.ebay.com
