songflytta
10 µW
- Joined
- Aug 8, 2009
- Messages
- 6
Hi
I'm fixing up and Electric bike for a friend and I'm having a problem with the motor stalling. I'd be grateful for any help anyone is able to supply.
The controller is one I picked up from Ananda drive. It worked great the first few times I tried it, however I stalled the motor for the first time this morning. (on a hill, the motor tried to retain power and then gave up and allowed me to roll back) When I got back on flatter ground I found the throttle didn't work at all. So I lifted the wheel and still nothing occured when the throttle was pressed.
If i roll the motored wheel back a little then I can get a little torque when I apply the throttle, If I then lift the wheel I can get it to spin, and it will continue spinning at full power. At this stage if I do a little jump start and throw myself onto the pick and put the motored wheel down then I can get it to take off. If I release the throttle at this stage and then reapply it then the motor power will resume. But if I allow the wheel to slow or stop, reapplying the throttle has no effect.
If I get on the bike and pedal to get up to speed and apply the throttle there is also no effect. It appears the motor needs to roll back a little before it will start to grab.
Is this likely to be a controller problem or a motor problem? I had a look inside the controller as I'd read things about shunts causing this problem. Unforturnately all the circuitry in the controller is covered with a gel, so I won't have any luck there. could I have perhaps broken a winding or hall sensor in the motor? Or if there is a controller problem is there a way of "reseting" the way it trips out the motor?
The other thing that I noticed was when I did get the motor running I could slow it down (provided I didn't release the throttle entirely and attempt to reapply) and when it was running quite slowly it seemed that power wasn't being applied consistently to the motor, there was instead one spot in the rotation where it appeared to struggle (based on the sound it was making)
As I mentioned I'd be more than grateful for any help, I have a few tools that I can do tests with such as an oscilloscope and DC power supply, but i'm not quite sure what to test. for extra info, the motor is 200W, planetary geared at about 5:1, Hall effect sensors, three phase power.
Thanks
Lawrence
Thanks
Lawrence
