Ballincollig75
My E Bike is not running - any help appreciated.
I know I need a new PAS and have one ordered. Part of the Disc is cracked off of the old unit.
Throttle not working - i.e. nothing happening when twisted. As far as I can see the Hall Sensor is in the correct position - I cannot see any obvious way of taking it apart to check the magnets - anyone know how on this unit.
LCD3 Screen not staying on unless I keep the On / Off button pressed - The Screen is getting 41.6V when I have the Battery connected. I opened the 3 Button switch unit and found nothing wrong in that I had continuity from the incoming wires on different points of the circuit board. Also able to get continuity from the Switch back to the circuit Board in the Display unit.
The rear wheel Motor is stiff as it should be when I short out the phases going to it. Turns freely when not shorting the phases.
This is a Bike that was converted to an E Bike at some stage.
I have pulled apart all of the waterproof connectors and re connected them - no joy.
No joy whether the Brake signal cables are connected or disconnected.
See photos of the relevant bits attached.
