I am carrying 500+ Wh packs, each that are weighting 7.5 Lbs (3 X 8s 5800 mah Zippy compact). Only one pack to ride the mountain trails (rides that are never more than 10 miles since my longest trail is 6 miles up and 3 miles down), sometimes two in town if I need to ride out of my commute, it happened a few times that I had carried as much as four to go riding the suburbs.
I agree that 60 mph is not to be sustained for a long time with a hub motor build. Yet, if you carry less than 1 kwh of battery capacity, you are unlikely to fry a big hub within your available range, unless you deliberately run it way out of its efficiency zone. For longer rides, you need to ease some sections to let it cool, so temp monitoring is a good idea.
I agree also that it is dangerous, but not more dangerous than riding a motorcycle at the same speed. Most of the time, I believe it is safer because it has better handling and shorter braking distance than any dirt motorcycle that I've had. Some windy days though, I feel it is too light weight for the speed that it rides. Then, building to ride 60 Mph on a wallbike is playing Russian roulette. You need to build a bike that is able to do that speed comfortably, with proper balance and geometry, stiff and sound, equipped with adequate brake and suspension components, and consciously maintained in perfect order. This kind of toy is not for the distracted and unconscious rider, but it is real fun in the hands of one who knows what he does.
