Sameguy
10 µW
I'm just getting into putting together an Ebike and plan on building my battery pack. I'm planning on using new 18650's and not quite ready to throw down for a spot welder and have read soldering has it's drawbacks, although I can solder pretty well. I was wondering what the collective brain trust thinks about simply building the structure of the pack with tubing, more specifically, 6-7 18650 batteries in each tube with some way of mechanically fastening the ends to provide contact between batteries. Then each set of 2 tubes could be a cell, then packing them all in a larger tube. The numbers below represent the cell pairs in the larger tube.
I'm not sure what to use for the tubes, end pieces etc but it seems like a simple way to construct various size packs that would not require welding or soldering to the battery ends.
