bruno_mac_douglas
- Joined
- Feb 20, 2020
- Messages
- 13
Hey Guys!
I'm actually studying to make my first ebike, and decided to register and ask your advice here after reading a lot of topics
the theory is a good first part, but I want to share with you my plans before ordering because the experience is also very interesting and I don't have any yet!
BIKE
Here is the beautiful baby I just bought, a 2009 Giant XTC Hybrid 1.0 I found used in quite a good shape and at an interesting price, with a rock shox tora 318 fork.
BATTERY
My idea is to make the battery myself, after I'll have built my own spot welder with a car battery
I'm still hesitating which cells to use, for now I selected these but I'll keep investigating on it:
samsung inr18650 35e
sanyo 18650ga refurbished
If anybody knows a better site delivering original batteries in europe I'm defininately interested! (by better I mean cheaper, while still being originals)
So the idea is to have a battery with specs like 3.7v 3400mah with 10A max discharge rate
So if I can fit in 70 batteries
so I'd design a 52v 14s5p with a 16.8Ah capacity which would weight around 4kg with case and electronics.
I want to use this bluetooth BMS (review here)
the reason is that I can see on BT which cells is failing, and avoid having all of them dying if I have a problem with one.
I also like that I can set the overcharge voltage and undervoltage, which would allow me to have the BMS control my charge/discharge levels to go to 20%/80% (which if someday I need to extend for a longer ride I just can modify the values in BT apps).
I also plan to put a GPS tracker with sim card to find it back if it ever get stolen and kick someone's ass
For battery case I plan to use this jumbo shark pack
the 70 cells version, but will the BMS and GPS tracker have a chance to fit in ? I imagine the space available for more battery in "new version" is maybe the spot where was put the BMS ? Do you know of any triangle (bigger) case sold alone ?
CHARGER
As a charger, I'd like to use a Power supply like this one:
First of all I always wanted to buy such a power supply, because I like to do DIY electronic stuff and I will be able to use it in other projects. Also, I imagine with this I could set the voltage to charge up to a certain level (like 80%) if my plan to control it with BMS is incorrect, or if I decide to set it to 100% and limit the charge with the charger instead of BMS. I guess I could also change the amperage to be able to slow charge or fast charge depending what I need. I'm quite unsure about this part, so any feedback on similar experience is more than welcome.
ENGINE
I'm still looking in that part, not even sure if I want rear-hub motor or mid-range.
However I think I'm more inclinated for a classic a mid range bafang bbs02B 48V 750w
I wonder if I can use a BBS02V 32V 500w as 52V 750w ? I saw some post that the firmware needs to be modified but the electronics and motor is pretty much the same, is that correct ? I found a new 500w 32v for sale next to my place for cheaper than aliexpress, that's why it seems interesting option for me...
I also so some posts about TSDZ2 with open source firmware which seems nice and cheaper.
my biggest concern of mid range is the wearing of chain and other elements that people talk about in comparative between hubs and mid range, is that so big the wear induced by a mid drive compared to a hub ? how much kilometer can you make with a new chain ?
Thanks a lot for your feedbacks
BIKE
BATTERY
CHARGER
ENGINE
