Newbiebikebuile2025
New here
Hi everyone
! Like my handle and the thread title suggests I am 100% new to ebike and ebike builds and I need help with everything from picking out parts that will fit my needs, to finding sources to get the lowest prices from safe & reliable sellers, to making the list of parts, to makoa list of tools needed for the build, to tips on how to put everything together, to ideas on how to ride and maintain my ebike build.
I Genuinely appreciate all input so thank you everyone in advance, you're the best for sharing your wisdom!
So I will provide a list of the main or most important things in an ebike and hopefully get some great advice from everyone on this site. Here we go
1.) want an ebike that can go 40+ mph. 40moh is a decent goal, 35mph would be a bare minimum if I can't afford more !
2.) I want an ebike with front fork suspension and rear shocks either mono or dual is alright with me, whatever will be alright, for a decent price, do it's job well enough and be good enough to be pretty durable for someone my weight of almost 220 pounds.
3.) I would love for my ebike to be motorcycle styled as far as the seat style which I would be happy if it was a flat saddle or any motorcycle style , not bicycle saddle style.
4.) I want my ebike to have a swingarm like a motorcycle. I'm not sure if this design of having a swingarm would make my ebike an e-, motorcycle? But after much experience with gas versions I know a swingarm is what I want for sure .
5.) I would like decent front and rear disc brakes for both stopping power and ease of installation and ease of maintenance, however, if it is much cheaper I would be happy to explore other good enough brake styles if anyone has any good
ideas!
Thanks!
6) I don't know if it's possible but I would like my bike to have tires that aren't really fat, I'm thinking a minimum rim size of 12 inches to maybe 20 or more inches I'd be open to ideas and opinions and the width I have in mind is 2 inches to maybe 3 inches and again open to ideas that fall inside or outside this range!
That pretty much finishes the stuff I really want kind of a certain way, unless persuaded otherwise, the rest is kind of much more up for any ideas
7.) I've heard about e-, bikes/ e- motorcycle that has (I think?) a hub motor or maybe a mid drive motor but setup where you can shift gears of the electric motor? There might be situations where the gear is inside the motor? And also maybe for mid drive where the chain that goes from the motor to the wheel changes what size sprocket/gears it goes over? (I am not talking about like bicycle pedal gears
lol)
8.) A nice digital display would be awesome, even like a cheap motorcycle style one with rpm and speed and tells time like a clock plus odometer-- again open to all ideas
9.) decent range battery but also like a versatile battery that has a good top speed charging rate and good top and continuous discharge rate. I mean of course I would want the best battery EVER
but I'd be very happy if it could get the bike up to 35-49 or more mph and last for at least 10-15 miles. I suppose batteries can always be added to or upgraded. Same with a lot of components which is why I think it's important to get the best part for your money for example even if I'm running my current build at 48 volts if a controller that can handle everything up to and including 96 volts is the same price or very little extra I would like to try for the 96 volt so that maybe some day
I can upgrade!
Thanks everyone for reading, for your great ideas, for sharing your experience and for putting up with a newbie like me!
