bowlofsalad
Hello,
I am working on fully assembling (choosing all the individual components, and putting them together) a bicycle wheel (non-ebike, mostly for practice) for the first time. The measurements I am working with are as follows, effective rim diameter is 392mm (mutant elektra rim), inner hub flange width is 52mm, and hub flange diameter is 60mm (shimano deore XT m756 hub). With these measurements I came up with 183.3 or so, so the plan with that was to use 184mm sapim race (14/15/14) spokes from danscomp.com (great price) and sapim polyax nipples all in a sexy black. I was about to call them up to place an order but I decided to triple check my work once more when I realized the spokes holes on the rim were offset from the center.
Both sides come up with 392mm, but I am still a little uncertain if I need to make any special accommodations in the calculations. One person has suggested to me to take the spoke hole offset in the rim (either 3mm or 5mm, depending on if I measure to the edge of the spoke hole or the center) and subtract that from the inner hub flange width. With this in mind, I come up with either 183 or 182.8 or so. If I am using 182.8 for the calculation, I could use 182mm spoke length, but being uncertain in all this I'd rather not guess with a difference of 2mm and the money spent on spokes. I could go with 183mm and be perfectly fine either way, but those spokes (dt swiss competition) cost well over twice as much and I still wouldn't be certain on what to do in situations of staggered spoke holes on rims (which I know is going to come up again for other wheels I have planned, ebike or otherwise). Maybe sapim race spokes come in odd lengths, but I haven't been able to find them.
Should I ignore the staggered rim holes in the calculations? If I should consider them, how should I measure the offset and how should I attribute that to the calculations? Thanks!
