aaronlim said:
dogman said:
You can definitely use solar power to do anything, provided you have the right equipment between the panel and the final use.
In the case of lipo, many of the chargers run on either 12v DC or 12-24v DC. So a lipo charger can run on the main solar power storage battery, be it lead, lifpo4 or whatever. This skips one of the efficiency losses, the AC inverter.
How do i actually bypass the ac-dc transformer on a typical lipo charger to save on this efficiency loss? I have one of those bmsbattery lipo charger and i'm interested in doing this
I think you're confusing lipo charger and li-ion charger. li-ion batteries are the standard ebike type batteries. lipo batteries are the explosive devices used to power RC cars/planes and sometimes ebikes.
lipo chargers (not li-ion chargers) are usually designed to run on 12V DC and require a power supply (transformer) to do the conversion work outside of the actual charger. So if you had a lipo charger, you would just not use a power supply or external transformer, instead you'd plug it directly into your lead acid battery bank. Though like dogman said, you'd need a high capacity lead acid bank to handle the load.
as far as i am aware, bmsbattery doesnt sell lipo chargers.
