amberwolf said:If the 72v charger is for a 20s lithium battery, then it's output is only 84v or so.
If the 96v of SLA is 8 x 12v batteries in series, then it's minimum voltage to charge them up just to "completely dead" is more than that.
So...no, it won't help.
You'd need a charger of about 8 x 13.6v (or higher depending on what the SLA say on the battery labels for charging requirements), which is 108.8v, if you actually want to charge them "full".
No, if you add another battery then instead of 8 it's now 9 times, so the problem is even worse.egromftw said:If its max output is 84v can I get away with just adding 1 battery to the series using stock charger?
amberwolf said:No, if you add another battery then instead of 8 it's now 9 times, so the problem is even worse.egromftw said:If its max output is 84v can I get away with just adding 1 battery to the series using stock charger?
You would have to get a higher voltage *charger*, not make a higher voltage *battery*.
Well, none of your posts said anything about that.egromftw said:Oh no thats not what I mean. The stock set up is 72v I want to add 2 batteries to make it 96v
As I said originally, if the charger is for a Lithium 72v battery it would output 84v.You mentioned the charger is likely outputting a max of 84v. I was wondering if that is true then would adding a single battery (going from 72v to 84v) be fine without upgrading the charger.
amberwolf said:Well, none of your posts said anything about that.egromftw said:Oh no thats not what I mean. The stock set up is 72v I want to add 2 batteries to make it 96v
So:
If this is your original SLA 72v charger, then it would probably output about 13.6v x 6 batteries in series, which is only about 82v.
You would have to check what it actually is, in either case.
A 7-battery SLA pack is 7 * 13.6v when full, which is 95.2v.
82v / 7 is only about 11.7v per SLA, which is basically dead.
So a charger that outputs only 82v will still not charge it.
As I said before, you will need a higher votlage charger to charge a higher voltage pack.
