Hi everyone,
after registering here, i was wondering what you´d think about my homemade ebike.
It´s a Cannondale Super V-600 with a Cyclone 500 Watt kit.
Since the motor always overheated, i´ve machined a new motor housing out of one solid aluminium block, integrating cooling fins.
Located on the rear side of the bike is the 36 Volt 20 Ah battery pack. The kit normally runs on 24 Volts, but i just hooked up this battery and noticed that it felt like it had more power then the 36 volt kit with external controller. The picture shows that kit, but when water got inside the controller and shortet it out, i just grabed my old 500 watt kit with the controller integrated in the motor, connected 36 volts to it and was stunned that it ran much better then that 600 watt kit.
The original planetary gear box was to long to fit between my legs, so i made a new one, using the gears, but manufacturing a new enclosure.
Yeah, those Cyclone kits aren´t too good, but it´s all i have for the moment and around here in Germany this type of power is totally illegal. But the permited 250 watts are such a joke.
