Tom,Tom said:Are you sure about the pics not being an M600? Unless my eyes are deceiving me the motor most definitely says M600 in the pics.
Drop Dead Fred said:Tripped across another one today. Sent an email for more info will post when I get it....
Supposed to be 150mm travel and 27.5 x 3.0\29 x 2.35 and weight is 3350g or 7.39 pounds
Animalector,Animalector said:Drop Dead Fred said:Tripped across another one today. Sent an email for more info will post when I get it....
Where did you find this one???
Thanks
Who are you, are you me? I just wrote about the same thing in an email not even two hours ago...Eddy Current said:Can this frames fit a 27.5x3.8 tire? Its is possible to order a bigger rear suspension triangle for the frame?
Hope they don’t forget about the fat market!
El_Topo said:Who are you, are you me? I just wrote about the same thing in an email not even two hours ago...Eddy Current said:Can this frames fit a 27.5x3.8 tire? Its is possible to order a bigger rear suspension triangle for the frame?
Oh and by the way ... m600 they are only 120nm peak for a short time like someone said?![]()
Yes, a bigger rear triangle would be great as this looks like a decent frame (from what I can tell as a layman).
If they adverise the frame for up 3" tires with 148mm axle, 3.8" should not be possible because the chainstays are not long enough for the increased diameter and not wide enough, the chainline is another issue.
While where are at it, Iwould prefer room for true 4.3" (4.6" advertised) tires though. If it is possible to keep the chain stays narrow you should be able to get a Q-factor of >190mm with that combination if you find the right ISIS crank arms with a bit of an offset and the right amount of clearance to the chainstays. The Bafang Ultra has a 150mm spindle, so I assume the M600 to have either a 136mm or 143mm one, so I am a bit unsure about the spider to get to a 65mm chainline but where there is a will, there is way! If we are designing a new rear triangle anyway, slightly angled sliding dropouts like the Otso Voytek would be nice too.
If carbon is not possible or too expensive for a small production run I would be fine with an alumium rear triangle as well!
Of course I know next to nothing about frame and rear suspension design so maybe just supersizing the rear triangle will throw off the design...
Another issue is fork clearance if you go for a true fat tire fork like the Mastodon. A Fox 34 27.5+ with 140mm of travel can fit a 4" tire though.
Can you get around this by using spacers between the fork and the frame or are there headset bearings that allow for this?
Then there is also this report about the M600 motor.![]()
Maybe one could get in touch with the manufacturer to ask them about a fat rear triangle?
Animalector said:The idea behind the m600 is not all-out power.. Bafang make the ultra 1000w for that. Its intended to be a light (er) weight but go-anywhere motor.
Its intended to be compared with the Bosch, Yamaha and Shimano ebike drives.
Andy
Eddy Current said:Animalector said:The idea behind the m600 is not all-out power.. Bafang make the ultra 1000w for that. Its intended to be a light (er) weight but go-anywhere motor.
Andy
Allright but it’s still more “punchy” than the others?
I ride a Brose not complains at all but sometimes I feel like I need just a little more without entering on the TQ or the Ultra levels
Thanks!
Andy, you seem to be involved in the manufacturing part of bikes.Animalector said:I visited the Enwe factory in China and saw this bike. looks good, I did not get to ride it though as it was a 3D printed model prior to them finishing the mold. It is the same as the Dengfu bike..
Andy
Animalector said:maybe 12-speed cassette with 4 of the inner gears removed, offsettting the cassette towards the drive side.
It would be a frankenbike anyways not something worthy of retail to consumers.
Andy
Animalector said:Yeah I know about the ex1. But the largest cog is still hard up against the wheel which is where the chain line is the worst (with respect to wheel clearance)
So even though it's 8 speed it doesn't solve the chain/wheel clearance problem.
Andy
