Let say I am carrying solar kit which is 300W panels with converter which charges the pack during the day. This 300W panels weighs around 25lbs with the converters and wires and such.
What is the alternative? I can carry 25lbs worth of battery. This should be at least 1KWh extra if I do carry a lithium battery pack.
If I get roughly 12+ hours of light in the summer with the inefficiency and dawn and dusk calculation, I think you can realistically get 5-6 hours of perfect sunlight. This is 300W*5hours = 1.5KWh of energy recovered. If you factor in cloud and imperfect panel angle, then you should at least 1KWh out of this solar setup.
So what are the pros of carrying solar?
You don't have to "charge" as much overnight. If you are indeed touring and stopping at hotels or RV parks, it might not matter much. However if you have a large enough pack, you might not be able to charge completely overnight. The solar kit can allow you to "charge" as you go. If you have a 1KW charger, and you plan to spend 6-7 hours charging, then that will give you realistically 6KWh with balancing time factored in. I am using 1KW charging because you don't trip some circuit breaker here in the USA.
Cons?
Yes, the setup will cost much more than just having battery. And the setup is going to be more complicated.
Worth the cost? Probably not if you are after the cheapest setup for touring. But if you want to go the max distance, then it might make sense. Also as solar technology gets more efficient, maybe you can get more back from the sun. But then again batteries will also get better too.
Cons?
