re: nonmagnetic shafting
I'm not a motor expert, but I'd say that non-magnetic shafting is better in this case if
not in general. With an out-runner, you have a shaft spinning inside of a magnetic material, the stator.
If you have magnetic material shafting, it would have energy coupled into it that is possibly
robbing flux from the stator... Even with a non-magnetic shaft, you may have eddy currents
induced that rob a slight amount of power. The distance from the stator to the shaft
is significant, 1 cm or more from memory....therefore, probably not much power is being robbed
in either case.... I dunno... makes sense to me...
For these new AC drives and motors, a few companies sell a current drain adapter to the end of the motor
shafting and case to prevent high voltage buildup on the shaft that can arc through the bearings and cause pitting of
the races and premeture bearing failure. I don't understand all of the physics mechanisms that causes the build up
of charge on the shaft.... high frequency eddy currents due to pwm switching of 440 volts being passed through
the rotor?
anyway...
More pics...More parts....More fabrication
Steel Clamps with Alodine Coating or somekind of yellow protective coating.
Much, much stronger than the stamped steel sheet metal conduit clamps.
The elastomer makes an excellent round to square transition.
The main tube is 2" diameter.
It is not a soft squishy elastomer, it is somewhat hard but can be scratched with my
fingernail...
The flat wings on the clamp flanges seem to be 1/2" bolt holes...haven't measure them yet.
I am stoked!!
And I'm just about ready to install the bearings in the sides...
I just need the shafting to help square and align the whole
assembly before I tack it down with hot glue and drill and tap all
the mounting holes for the bearing housing flanges.
The 15mm shafting (should have done 1/2") will be induction hardened, with flats spots for
the pulley and keyway for the sprocket. It will also have grooves for circlips
to retain the shaft centered between the bearings. It's overkill, maybe I'll
actually work out some design calcs on the next one...
And just wait till you guys see my new badass motor t-shirt...any of
you Black Sabbath motor nerds will love it...
More to come...
