Centaur By E-ZBikes
LockH
1 PW
Ummm.. Started out in Victoria BC Canada, then sta
Seems there's a new Centaur in town...
Seen here:
https://www.touchofmodern.com/sales/centaur-by-e-zbikes?open=1&utm_term=centaur-by-e-zbikes
Electric Carbon Fiber Bicycles
Real bicycles with on-demand intelligent PAS, All CENTAUR E-Bikes are made to order, and equipped with the BOFEILI Gen2 motor, the most compact shaft type mid crank electric motor on the market. With no internal gears to wear down, up to 33 speeds, and a lightweight frame, these bikes require almost no maintenance, and will let you make the impossible possible.
With various flavours, with most expensive Carbon Pro // CB27-MTB-LTD (handmade, made to order)
Looks awesome, and I was impressed right up to the "Almost no maintenance" statement.
Hydraulic brakes, exposed chain system using that thin little chain all high gear count bikes have to use, and running the motor power through it, An inverted fork with it's low exposed seals and low stanchions that can be scratched by everything.
I'd call that high maintenance.
