Are there any major differences between a 20" and a 24" wheeled tricycle for adults 6' 250lbs riding gravel back alleys hauling not much I can figure out the power I need, I figure 1-1.5kw whether hub or mid drive, weight is not of concern, at most 40lbs if ever more likely 10-20lbs and I know there are more people over 300lbs riding around.
Biggest factor I can figure is stopping every 30'
Hills not a factor, winter might be a factor as there is more ice in the back alleys so diy studs and might switch over to motorcycle rims if flats and diy studs force me to a heavier, more solid tire.
I know they are top heavy, not meant for speed or cornering. Its not a cruising trike, be way to combersome dealing with stupid frocks all the time with a wide trike that I deal with on a daily basis on normal bicycle.
What are your thoughts?
