Chalo
100 TW
If she rides it at times when she'd otherwise drive a car, everybody wins. I hope it works out that way. If she gets to riding it a lot, you should consider coming up with something better than a Mongoose (a bike I'd only give to a bum for free, and then only if I wouldn't be expected to maintain it).
Unless you measure it, you don't know how many amps the thing is actually moving around. The 60A controller may in its specific setup be delivering fewer amps than your 30A controller does.
Motor phase wires are usually short enough to have little effect on power, at least within their rating. Keep in mind that wire resistance is a function of both cross-sectional area and length. Your controller has traces on its circuit board that have to transmit the very same power, but are probably much smaller than the phase leads. Consider the legs on the FETs themselves, for instance.
