I just bought a 36 volt controller for my 1018 Unite motor. I haven't drilled my holes yet, or run my plumbing, but of course I will have to if I don't want to cook my motor.
I want to give my motor extra-special treatment, so I also want to add a spray misting system, which will spray a fine mist of distilled water if my motor heats up past some threshold. Here is where I need a little bit of help.
I'd like to put a thermistor or two (for the added redundancy, perhaps, in case one fails or gives a bad reading) inside the motor casing close to the windings. I want to use a simple analog circuit to control my misting system and blower, based on the temperature inside the casing. I'd also like a potentiometer so I can adjust my "threshold" values for the blower and misting-pump.
If the temperature exceeds threshold 1 (30 deg. C or so), the blower starts, [strikeout]and blows proportionally to temperature[/strikeout] (unnessarily complex). If the temperature exceeds threshold 2 (adjustable by my potentiometer) the misting pump blows a burst of mist, maybe for 5 seconds or so. I don't want it to mist constantly because I think even a short burst of mist will cool the motor plenty. However, it will take a little while for the temperature to drop as a result (thermal inertia). At full "cooling power" I would like my mist sprayer to spray 5 seconds on, pause 10 seconds, and cycle like this. The time intervals don't have to be exact of course, but you get the idea.
Now I know capacitors can be used for the time delays, and zener diodes can be used to set my thresholds somehow, and maybe relays can be used to switch my blower and misting-pump on and off, but I lack the confidence to try to design the circuit myself. I've a limited understanding of such things, and have never done it before. So... can anyone help?
