Looking for help sourcing a motor for my ebike setup
If you want high speed and high torque you have to compromise on gearing, if you want to use a derailleur to try and get around that the compromise is how much power you can put through it
Do you know of any issues which would arise if I just use high chain speed on a middle gear (my 22 tooth gear for example)? That way I could use the gears with good teeth engagement, would have a small load on the motors and chain, and I would still be able to have the rolling speed that I want. I'm thinking, 2 or 3 (300rpm for simplicity) times the normal max cadence of a human. The chain would move at ~11mph which seems quite reasonable.
Well, it's not beyond what you'll be doing if you run two motors with one controller--you'll have to do that in order to do so. ;)
(assuming they're not brushed motors).
That process sounds intimidating and it would probably be challenging enough for me to worry about doing. I think I'd rather not do it just so that problems that my bike ends up having are things I can fix on my own. Learning how those motors work and learning to troubleshoot their problems doesn't seem to be outside of the realm of possibility though.
I'd guess most of these aren't designed to optimize for sound reduction.
Which kind of equipment?
I'm on an FRC robotics team we work with entry level robotics equipment meant specifically for FRC. We get most of our spur gears from West Coast Products and our planetary gearboxes from Rev which also make the motors we use. Some of these motors are terrifying! We use Kraken x60s and they are hardly larger than the hobby rc motor that I mentioned above, but they're rated for 360a and can put out 7nm of torque. That along with the fact that the ESC is built in and they have very accurate continiuous encoders means they're very capable, and very expensive. They could be worth it to be if I could know for sure that I could keep it cool.
I'm not really sure what you mean, the 22 tooth on the cassette? That kinda defines pretty low chain speed because you can't make the front drive cog (which from your design is separate from the pedaling chainring?) that much smaller than that so you have a very small amount of reduction so unless you are going very fast the chain won't be moving that fast and will be under a lot of tension with those small cogs pushed to their limits to have a serious amount of real wheel torque. If you absolutely will not give on the derailleur it is possible to remove the smallest cogs and shift it over, modifying the mech as needed so you have fewer gears, all on the larger end and all closer to being in ideal chainline. Then with a small driving front cog you can have speeds and some amount of torque.
But it still only makes sense if you abslutely have to pedal it. Multipled gears with an electric motor is almost always less efficient, and yes I said almost, the absurd efficicney in terms of power loss and weight of a derailleur (when compared to basically any other multiple gear system) gets close but you still have to have pretty weird operating ranges. Honestly why not just have two chains on the right side, one to the motor with a large reduction and one to the chainring as a single speed you can pedal for emergencies. You don't even need to keep the pedal chain on which could simplify some things.
It all depends on the power and torque you are actually looking for with all of this, you can look at other builds and such for some general ideas of what power you can drive through what systems. You can put a fair amount of power and torque through a derailleur but even many BBSHD builds I've seen people replace them with single speeds for durability.
"those motors", if you mean the type you're talking about using two of that would have to be locked together to use with one controlller, are just the same kind you're already using, if you are using BLDC 3 phase motors like the typical RC motor.
Brushed motors are very very simple to use, and dont' even require a controller if you have a switch big enough to handle the spark/etc from engaging under load and you don't need variable control over them. ;) But the controller itself is also much simpler than a BLDC (brushless DC) controller (which you're already using iwth typical RC motors)
That sounds like a challenge. :)
The Kraken x60 looks interesting, is apparently a low-kV low-rpm type of motor from the first couple results on a web search, which is why it takes such a high current, all relative to the typical RC motors that have a high kV and use thousands of RPM to get the power output they do. So they'll be quieter just because they are not spinning as fast, even if they are still using gearboxes (of which I saw several types specifically made for them, including some that drive small (aimable with a separate servo motor?) caster wheels).
Without experience with those motors, or a dyno chart, I'd guess that they are not rated to take that 360A continuously without significant external cooling; they're just too physically small.
I would guess that they are probably better suited to drive a ground vehicle than the higher RPM types, but you'd probably still have to run an external cooling system.
Additionally, wiht a built in controller, you have *two* sources of heat within a small space; in many applications this isn't an issue but any application with high continous power usage means more heat build up more rapidly in a smaller space, so they usually require significant external cooling.
If they're using continuous encoders (like SIN/COS) that makes them much more useful for positional control, exact movements, etc., and can make them easier to control in any other application (some of the BLDC powerchair motors also use SIN/COS). But few controllers can read those types of encoders (almost all of them are either sensorless or UVW-ABC hall sensor type).
As for keeping it cool, you can find out what it would take to do that by testing temperatures of the ones you have access to under known loading conditions, and extrapolate from a series of those conditions and measurements what it would take to keep one cool under your loading conditions.
Right, that is clear to me. I just mean that I do not understand how brushless motors work and while it may be within my ability to learn how they do work, I worry that even that knowledge will not let me fix the problems that may come up with that setup. It feels a little too far from what I'm familiar with so I will probably not design around that setup.
You are quite right. Our competition matches are only 3 minutes long. When we are testing our robot for long periods of time, they can be plumbed up to forced air cooling. No water cooling though unfortunately. That's because they're actually outrunners under the ourter cover which I can only assume is cheaper.
We usually use them in short bursts, no more than a second or two at full power. Usually that's all it takes to get a heavy component from one place to another, then they use minimal current to keep it in place for as long as we need it there.
I just mean that I will treat my 22 tooth gear as if it were my fastest gear. Then I would adjust the gear ratios or the motor that I eventually choose to go with to make it so that I comfortably reach my design speed in that gear. I would optimize my chainline to use only the 1gear to the 6th gear (22 tooth)
I'm really trying to work around removing my 12speed because I am very uncomfortable with the idea of taking the bits that distinguish a bike away from my project. Once I stop working with bike components, it's out of the realm of my experience, I also just love bikes. This project comes out of love for biking, and in a way, it feels like a sacrifice whenever I make the project any less like a bike. Once I am comfortable working with these ebike components, I want to redesign around a torque sensor just to better replicate riding normally. I know that this logic is flawed somewhere but these are the feelings that I am having as I try to recognize what exactly I want and how I can achive those wants despite the design challenges.
As an aside, I'm going to look into replacing my drivetrain with an 8speed so that I can keep long term costs low.
Huh that is interesting, also VESC controllers can use all manner of encoders sin/cos included.
Sorry, I misspoke. The X60 has an absolute encoder, not a continuous encoder. As far as I can tell, continuous encoders do not exist or at least is not a term that is widely used.
Ah. I don't know the terms used for all the various encoder types, but continuous is as good as any for a SIN/COS type, where there are two sensors 90 degrees apart on a ring that is magnetized in a continuously variable pattern of a repeating sinewave of strength/polarity. These may have the same number of peaks as rotor magnets, or it may be more or less than that such that the controller must be designed to do more math to determine rotor position from sensor position.
But either way, the signal is continuous, and analog, as opposed to the UVW-ABC type hall sensors where they use a combination of three sensors spaced some physical distance apart, that is equivalent to (commonly) 120 (or 60) degrees apart electrically for the stator / phases, and detects the rotor magnets passing; there is no separate encoding ring unlike with SIN/COS and other encoders.
So UVW-ABC is cheap and dirty, very noisy (the sensors are embedded in the stator teeth so all the magnetic field garbage from driving the motor *plus* the rotor magnets passing is detected by them, and sometimes has to be filtered out by the controller. To help with that, most of these use open-collector latching bipolar halls, so they only change state when a magnet of the polarity opposite to what changed the state before comes by, instead of whenever fields in stator / etc happen to change enough to trigger it.
Ah yeah that works better but I still suggest you slide the cassette over if you can to improve chainline. I mean my rear drive is all bike parts, the rear cog is a standard 58T narrow wide chainring with an adapter to the HG spine. My bikes are very much designed to be bikes and not motorcycles in terms of how I feel when riding them. I don't think the driveline parts really change that but other parts certainly could.
My point still stands though you should decide where you want the power level to be, because "I want it to feel like a bike" and "like a dualsport" are very different things. Why not just aim for 1500-2000w which is plenty for riding it like a bike, even a ultralight motorcycle in some conditions, is far easier design wise, and will end up being much closer to a bike. If you are regularly using any more power than that it doesn't work like a bike, going faster than that power (assuming appropriate gearing) starts to feel sketchy and use enough power you start to add a lot of weight in battery to have any range. Accelerating with more power than that is fun but I don't know that it's worth it, I only do it rarely mostly I'm just cruising around. And off road (again assuming gearing is correct) you rarely can use more than that unless you are doing hard accelerations, very very few hills are so steep and difficult that I can climb them with my 5Kw bike but could not with my 800w one, and my friend's (CYC stealth) 2kw bike had no problems riding like a bike on bike trails with ease.
I just think that is a real nice power range for a bike bike, using a derailleur and pedal assist when you want it (but even at that power you aren't helping much. And it allows a reasonable sizes motor with a belt, chain, or gear reduction without adding too much weight. Please don't use a worm gear, adding 20% more batteries and motor than you need for no reason is silly and it will be way way harder to make than a belt reduction. Like 1-2 stage belt reduction, you can buy the small cogs online easy, belts are easy, you can print or machine the large cogs and the frame no problem. Efficient, quiet, cheap, reliable. Also on the quiet aspect, if you want to ride it like a bike on bike trails around people you want it to be super quiet because while most people don't care you do feel self conscious about it and that can stand out more than if you have a derailleur or not.
I totally agree, I was browsing for a motor last night and realised that since I am still using a few gears on my casette, I shouldn't have to worry about using as much power as I was asking for. I think looking for 2kw will be plenty since I like the headroom to keep temperatures low.
I also arrived at this conclusion, leaning toward belts but gears are a fallback since I know they'll work. I have used HDT15m belts before but they're just not made for this kind of torque. I'm looking onto other belt profiles, I could probably get away with 5mm powergrip GT3 or GT2. I'm worried about the belts skipping since I'll end up with at least one smallish gear. I might need a tensioner to improve belt tooth engagement. I'm also looking for a place to buy the small front gear that'll drive the chain and be connected to the end shaft of the gearbox.
Speaking of safety, as that's one thing I can comment on here, I mostly quit mountain biking and moved to motorcycles because MTBs are just so much more dangerous - talking strictly about offroad here. On a motorcycle, you'll have a proper full-face helmet, back protector, ideally rigid knee braces and certified bump protectors elsewhere. The size of the machine also commands enough respect to not ride beyond my ability, and take things slowly and humbly. In effect, while falls happen to me all the time, I come out of them mostly unscathed. And yet I can come back from a casual bike ride with a thigh of road rash and bruises that take weeks to heal because I felt overconfident while reaching for a water bottle or navigating a small jump.
Safety is a function of many factors and mentality is probably the largest of them. If you think you'll escape wanting to ride faster, beyond your abilities, just because your bike will look less like a Surron then I'd recommend thinking again. 2000W is plenty enough to get yourself into speeds that will hurt quite a lot with the feeble gear MTB riders wear, and the only thing preventing the unfortunate conclusion will be the way you approach your riding, regardless of the engine power.
haha, i switched from motorcycles to MTBs because riding a motorbike on public roads seemed a bit too dangerous for me (not enough protection from traffic collisions, human body not really built to handle crashes at higher speeds). Of course hitting a rock or a tree while riding MTB is not a pleasure either, so choose your poison.
Yeah, motorcycles mixed with traffic is something I stomach for commuting but wouldn't recommend otherwise. (Honestly, nothing mixed with traffic, while we're at it. Cars just suck.). Offroad is much more fun anyway.
I mean 0 watts is plenty to be dangerous on a bike given a suitable hill. It all depends how you ride, I feel and historically am much safer riding offroad on my high power E-MTB than on my dirtbike (which has sat in my garage for many years now unmoved because it's less fun, harder to use, and more dangerous (to me)).
And I think an ebike can be safer than an MTB if that is your goal. I ride with a full face DH and a full set of pads and while that would often be uncomfortable if you were pedaling, I'm not, so it's no issue. I also think using a throttle does make a lot of difficult riding much easier and more fun. Like I can focus more on the terrain and what the bike is doing without having to also think about pedaling, pedal strikes, balance offsets from pedaling, etc. And I think accidents when riding an MTB are much more likely just down to being tired, I still ride untill I'm tired but I don't ride anything too extreme when I am. The idea that people seem like enjoying being exhausted after a long climb and then they want to ride down some highly technical and potentially dangerous trails just seems like a reciepe for getting injured. If you're in good shape sure the first few laps are fine but then you start to make mistakes. Even an E-bike that you mostly pedal allows you to control your effort and physical limits.
And unlike a dirt bike I'm moving much much slower and I still think it's much more engaging and fun. Most people ride dirt bikes at speeds for fun and no matter what more speed means more energy means more danger. And when riding a dirtbike slow it's either some hard enduro stuff where you are flinging a machine easily heavy enough to injure you by falling on you around or your are riding trials which is the exception I think. Meanwhile on my EMTB I can ride tighter and more technical terrain at slower speeds with the same levels of engagement and the light weight means I have more control than on a heavy dirt bike. The weight and torque means I can ride it like a trials bike when suitable.
That's true to a certain extent, but if EMTBs only had benefits over enduro motorcycles, everyone would take them to Erzberg ;)
Heavier machines, while requiring much more skill, expertise and to a certain extent strength, can cross terrain completely unavailable even to powerful eMTBs. A proper enduro bike has enough power to launch itself onto or over obstacles of 1m height or higher, from no kicker whatsoever, has tyres with enough grip to keep traction during that, has wheels strong enough to absorb the bump and a lot of suspension travel to keep you in control both on landing and at higher speeds. Going lighter means sacrificing all of those things, unfortunately. As long as the terrain you ride through is passable on a lighter machine, though, and you have no ambitions to progress to harder obstacles and steeper climbs, I generally agree that lighter is typically better.
I mostly agree, but that is also my point, launching yourself 1m up on a bike weighing a couple hundred pounds is not exactly safe. But those also assume you have the skill to do those things, my bike is still well more capable then my current skills and that is probably the case for most no matter what you are riding. I enjoy pushing myself on as hard of obstacles as I can find and doing so in a more dangerous way when either way I don't have the skill to fully take advantage of what the bike can do only slows things down since I'm less likely to take risks.
Also being able to find a place to ride the bike even if I'm in a grey zone of power levels but respectfully riding on MTB and multi-use trails is more important.
Now where I perhaps disagree is the limits of lightweight (50-150lbs) electric bikes, I think we're only starting to see what such machines are capable of and it won't be long, even now we see hard enduro electric classes that really edging into dirt bikes territory. I think it's partly battery technology limitations, bike design, and rider skill. I mean a skilled bicycle trials rider can jump 1m vertically too so I think part of what we are seeing is there isn't the large base yet of people training on this weird middle zone of lightweight e-moto/high power e-bike so see what they are capable of at max skill level. Will be very interesting to see where these things go.
Not really, I'm with you with everything that followed. I'd only add that we're also missing parts like wheels, tyres and suspension that would fit that "grey zone". Right now it feels very much an "either-or" proposition, where you either use "bike" parts or you use "motorbike" parts, and everything in between is unavailable or not up to the required (very high) standard.
I would personally love for my bike to weigh say 75kg, but to get that weight and not compromise on aforementioned performance, the savings would need to be holistically spread across the entire machine.
Exactly, and I think we will see more parts like this over time but may be slow. I think though as battery energy density keeps improving this weight range will make more and more sense.
When I first built my bike I was super worried about weight but eventually gave in for most things because lighter weight starts being very expensive ending up at around 60lbs (27kg) currently and I found the weight really isn't an issue and helps in some cases. Too much higher and I'm pushing DH bike components and mixing in dirtbike components starts adding weight very fast which starts to require more dirtbike parts and then it's all compromise. I also think the bike to rider weight ratio is one reason I like these bikes, at 130lbs (59kg) I feel like a child on a full sized dirt bike and my weight as so little effect on the bike it sucks.
I m not in the same league you are looking for, I started looking at matching a Lapierre eZesty AM LTD light weight e-bike costing over $9000, so using a TSDZ2 with the OSF firmware and a 36V 10ah battery I ended with a e-bike weighing around 40lbs for just over $600 with me weighing 140lb it has given me a e-bike light enough to flick around thro' the local forest with a range around 25 - 30 miles. I do ride another e-bike with a 48V TSDZ2B but mostly have settled on the the lightweight.
Hey, quick update. I'm pivoting to a left side drive that connects to my rear brake rotor mounts, I was worried about losing my rear brake so I will be wanting to use regenerative braking through VESC. I am looking for a motor that can handle around 80-120 phase amp bursts and put out enough power to carry me up some steep hills on pavement and in the dirt (max of a 22% grade). I've determined that I am looking for at least 130nm to the back wheel and 540rpm (wheel) max so that I can comfortably move at 35mph.
I was looking at running two Flipsky 7070s driving one belt since they're pretty cheap and kind of ideal for size and burst power but Flipsky in general has a bad reputation so I'm trying to move away from that. I was also looking at some of the Maytech options but they're really physically small so I doubt they'll have the peak torque I'm looking for. They also don't have torque curves published or anything. Are the smaller motors viable?
I am planning on using a Spintend dual motor controller which has fan outputs for both the controller and the motor so the motors will have some decent cooling.
I am hoping to 3d the Pulleys so that I can have a really versatile reduction. I'll fix the issue with the shaft bore stripping out by using metal press fit or heat set inserts that I'll press into the pulleys. The motor mounting will start off as 3d printed so I can play with positioning. Using two motors mounted in the way I want to mount it forces me to use an external tensioner and that lets me have lots of room for different pulleys and I also shouldn't need to replace the belt to change the gear ratios and it encourages more tooth engagement.
Doing two motors even if on the same shaft with one controller seems more complicated than just using one bigger motor. Thr 83100 motor has some of the best parts available and u can get it unbuilt so can wind whatever kv
I do regen braking with a two-way halfgrip throttle using vesc 7500 and 84100
A 10:1 ratio with this motor works great.
Woah, that bike frame looks sweet! I agree with your opinion opinion of using two motors but I was thinking that I would have to compromise if I wanted to get the power I need without a really thick motor.
Where did you source the motor parts? That looks like the housing for the flipsky/ feerchobby one.
Does the wide motor get in the way of your pedaling? Do your feet rub on it or get caught or anything?
The motor doesn’t stick out much and not a problem with pedaling
Freerchobby sell the 83100 in parts and where I got it (I added a new center part for bigger bearings).
If u can get the gear ratio high, and can cool the motor well enough, no big motor is needed
This bike is for sale at $400. A steal.
Feerchobby and flipsky have exceptionally bad reputations (they also sell several of the same rebranded motors). How much cheaper does the unwound motor cost compared to pre-wound motor? Have you had issues with QC or with motors being finicky? Maybe throwing a magnet or bad tolerances?
I’ve gotten many motors from them and all are fine. The ingredients are second to none with .15mm laminations.
I forget the cost of unwound but think was $200.
