snorkelgnu
100 µW
I converted my city bike to electric and thought I would share the results. I live in San Francisco and my daily commute requires climbing 12%-18% hills. After much research and advice from this board, I decided on a Xiongda 2-speed motor paired with Luna's 52V Mighty Mini battery. Here are the pics, and more details below.
Before:
After:
I finished the build about a month ago, and I've been commuting by bike nearly every day since then. I am very pleased with the Xiongda motor. With the 52V battery, the motor tops out around 21mph (34kph), which is fast enough for me when biking on crowded city streets, and acceleration from standstill is great. My bike has an 8 speed gear hub, but most of the time I ride in either 4th or 8th gear. If I ever build another bike, I will probably switch to a single speed or 2 speed hub to save weight.
It really shines on hills, and I can climb up the steep hills (20%+) around my neighborhood in 4th gear without needing to stand or sweat. I still need to pedal, but the effort is similar to walking up the hill. I'm usually climbing around at 8mph-10mph. My daily commute is around 4 miles round trip, and I usually charge the battery once a week, give or take a day or two.
I ordered directly from Xiongda rather than Luna Cycle, because I wanted the option to ride without a display. As it turns out, the controller had a 6V output for powering lights, but it requires the display to control the lights. I ended up stashing the display, controller, and battery in a bag with a 3D printed bracket to so that the display is visible at a glance from inside the bag.
I also wanted to remove the bag and electronics easily when locking the bike outside, so I consolidated all of the controller signal wires to a single 24 pin ATX power connector and the motor power wires to an MT60 connector.
This was my first bike build, and Bonnie at Xiongda was very helpful in answering my questions. I had a bike-savvy friend help with the wheelbuilding, the fork required stretching and shims to accommodate the disc brake, and I needed to do some dremel work to mount the PAS. Otherwise, the build went very smoothly.
Hope this writeup is helpful. Happy to answer any questions.
Before:
After:
