Color and Phase Sequence of Xtyle and other motors?
The7
Vancouver
Xtlye motors use Yellow, Green and Blue (Y, G, B) to mark the phase winding and the Hall sensors wires.
The motor of AL1020 uses the same color code and the phase-sequence is Y-B-G. The spacing of the Hall signals is 120 deg and the output voltage (V yb) leads Hall signal (Hy) by 60 deg.
1) What are the color code used in other BLDC motors?
2) What are the phase-sequences of Xtlye motor and other makes?
3) The spacing of Hall signals?
4) The phase shift between the output voltage and Hall signal?
Wonder if anyone had observed the phase-sequence in these motors using Oscilloscopes.
