HoverBoarder
- Joined
- Oct 10, 2010
- Messages
- 78
I have an idea for a generator and motor that could produce power using a sealed ball filled with compressed air and rings of magnets arranged in Halbach arrays.
Halbach arrays are ways of arranging magnets to focus magnetic energy in two directions. This generator works by pushing two rings of magnets on semi-elastic bands arranged in opposite Halbach arrays together using an industrial strength ball filled with compressed air and maglev bearings for the outer ring. When acting as a generator, the ball of compressed air would stay sealed causing the outer ring to continually spin and create energy. Needing only periodic refilling of the compressed air ball.
Halbach Array Configuration
When acting as a motor, the amount of compressed air could be varied to act as a speed controller by pushing the rings closer or farther apart, and thus speeding up or slowing down the spin of the outer ring. An arrangement of three wire of wires can also be placed on the inner Halbach array in a Linear Synchronous Motor (LSM) configuration to act as an electromagnet for higher motor speeds. This motor arrangement was used with magnets arranged in Halbach arrays on the Inductrak Mag-Lev train system developed by Richard Post from Lawrence Livermore National Laboratory.
LSM Three Phase Wiring
A good presentation on the Inductrack Mag-Lev train which discusses the Halbach arrays and LSM wiring for propulsion can be found here:
http://gcep.stanford.edu/pdfs/ChEHeXOTnf3dHH5qjYRXMA/09_Post_10_11_trans.pdf
Let me know if you have any comments or ideas on this.
Thanks!
Thanks!
