Thanks wb9k for those test results, I found interesting, my thinking was from an a.c. current perspective, as personally I've only really used greases such as Alminox on a.c. HV terminations and its highly impregnated with suspension of disgusting zinc (if memory serves), for Al/Al use, i remember my colleague being given a different type, which was a light colored, murky brown grease.
Now we test all cables and joints for milliohms, (for use on 132kV substations) and this new grease failed every test and the resulting lugged cables were scrapped, my thinking was along the lines of what would the manufacturer of a conductive nanotube grease recommend it to be used on, in respect of parameters, voltage, current, ac/dc, freq?
Eg (might be over thinking here), but does the conductive grease work better for like micro-arc flash over points on the joint at certain voltage or could it introduce itself as a small negligible value capacitance points on the surface with ac current, allowing improved ac conductivity?
As professional sparkies, we're often more concerned with installation/ mechanical issues, so generally we'd follow the standard procedural methods for terminations of conductors.
With lugs, generally following the manufacturer's documentation.
For automotive purposes, most are multi-stranded cables for the higher degree of flexibility, (vibration), these are terminated in bell lugs with the viewing hole, then crimped using recommended crimper and pressure.
Sometimes if the lug is a fair bit longer than the crimp die, I personally like to double crimp a lug, with a space between the crimps.
The only time I've applied anything to a joint recently, has been silver soldering busbars, together.
Can't remember introducing solder into a lug for years, as I think Luke infers, it can cause a point of inflexibility where the cable meets the lug.
Back to your nanotubes, been reading up on the conductivity and find it fascinating, the conductive types, how they quantum channel the electron flow, amazing stuff.
Scuse the ignorance, but relating this to a lap joint, do the conductive nanotubes align for conduction in any plane, like a sphere, or is it just relying on the abrasive quality, as the latter I don't think would give an improvement in conductivity, just like other greases, it's mainly to keep oxidation away.
Hence in a fashion, it is a 'conductive' grease, by helping to maintain the conductive integrity of the joint.
