I have an ebike with pedals, a rear hub motor and an 8 speed cassette.
I replaced the controller with this kit BuyWeek Elektrofahrrad Brushless Motor Controller Kit, 36V 48V 250W 350W 17A 3 Modus Sinuswelle Controller T5S LCD Display Meter 130X Daumengas Kit für E-Bike Elektroroller : Amazon.de: Sport & Freizeit. I kept the original motor, which is a Jinhua Vision Industry https://www.decathlon.de/p/vision-motor/336228/c1m8668416, while the original controller was rated 20A 48v.
This new controller is 17A 48v with OMD2 over UART protocol (JN compatible). I have configured it with multiple possible speed limits, lower and higher, including the highest possible setting during tests.
The controller applies motor braking when the motor's RPM exceeds some constant limits. This is not a speed limit, but a RPM limit, because the speed limit for motor braking varies in accordance with different wheel dimensions, but the RPM appears to stay the same.
For example, with a 20" wheel setting, the limits are:
Level 1 - 16km/h
Level 2 - 22km/h
Level 3 - 26km/h
Level 4 - 32km/h
Level 5 - unknown
When going 25km/h (level 2), when I lower the assistance level to 1, the controller uses the motor to brake pretty hard until the speed reaches 16km/h. If I change the assistance level to 0, the controller does NOT brake at all, so I can pedal faster, as fast as I can go.
Setting the controller's speed limit to 0km/h results in the controller always actively braking the motor. Setting the controller's speed limit to 100km/h results in the controller applying varying speed limits depending on the selected level as above.
Is there a way to deactivate the controller's motor brake behaviour? I could not find such a setting in the menu.
Level 1 - 16km/h
Level 2 - 22km/h
Level 3 - 26km/h
Level 4 - 32km/h
Level 5 - unknown
