From what I understand from Justin's multi motor video it is best to use torque based motor controllers when setting up a multi-motor configuration. I am designing/constructing a delta trike with two hub motors one in each rear wheel and I am looking for advice on which controller to buy.
Design spec:
- delta trike
- two rear wheel hub motors (QS205 4kW V4)
- tot vehicle mass incl. driver, 300kg
- min 24S18P li-ion pack
- min 100kph nominal top speed
- est. motor effective power draw at 100 kph is 2 x 3.5kW
- est. req. cont. delivery per controller: 4.4kW
- lively acceleration would also be nice . . .
. . . so which torque based motor controller should I consider?
I apologize if similar topics have been covered before, I have searched but not found clear ones, thanks in advance // N
Design spec:
- delta trike
