grimbasement
I took my bike on a long touring ride over the last weekend 170 miles round trip from Salt Lake City to Brigham City. The setup was a Hy-power cycle modded 25 A 12 fet BMC controller that I've had for a couple of years, a v2 BMC geared hub motor a brand new 48 V 20 AH Ping v3 battery and an old hammered 36 V 20 Ah that has about half capacity and a 2.01 Cycleanylyst. The BMC controller modded by Hy power has 2 settings controlled by connecting two wires one for 36V and 1 for 48V. Since I was going for long distance I used the 36 V for the 10 Ah it would give me for the flats, and then switched over to the 48 V. It worked just fine, except when switching from one pack to another it took about 4 tries of resetting by unplugging the power to finally get the throttle to work again. CA would show a connection a fully charged battery and everything should work. Yet it wouldn't I was ready to start just riding with no power (not something I want to do with 150 lb bike) and decided to reset it one last time and it finally came on, that happened both times I switched from one batt to another. So that's the annoyance... I want a conroller that is just going to work, not worry me about if I'm going to be left stranded or not. Parenthetically, this is the second HyPower modded controller I've had issues with so I'd like some suggestions for a better controller... so that's the annoyance. Other than that the rip was awesome and I had a great time out exploring and having a great ride with no other mechanical incident on the ride itself.
But now after getting back and charging the battery again, I plug in the battery the Ca comes up shows proper voltage fully charged etc... until I put even the slightest load on controller the CA cuts out and everything is dead. But if I lift up the rear wheel I can spin up the wheel under no load with no problem at all. So any idea what to look for? I've checked all the conections etc but i haven't tried the 36 V battery to to see if the 48 V Ping is having BMS issues.
So what typically causes a failure under load but not with zero load?
