I found this forum after reading about electric street bikes such as the Enerjica and Zero. I have a complete GSX1100G along with a parts bike to use for parts fitting, and after viewing a YT video where the owner converted a Honda Sabre to electric, I thought this would be an interesting project. He makes some pretty bold claims such as 145 MPH top speed and a range of 155 (mountain terrain), 175 (highway), & 190 (city) using 36 120AH batteries. So far I've been mostly lurking, but am learning more every day. Any positive commentary is welcome, as I'm brand new to this concept.
My plan is to keep the shaft drive as was done on the Sabre. I don't think I need a motor as powerful as the Netgain Hyper 9 he used, so I'm looking at what all is available. I want to avoid placing batteries where saddle bags would go, I just don't like the look. My goal at this point is to achieve similar performance (74 KW or 100 HP @ 7500, and 99NM or 73 lb-ft @4750) and a highway range of around 100 miles. My daily commute is 70 miles round trip over mostly open roads on a mildly rolling terrain at an average speed of 60-65 MPH. While I could possibly recharge at work, I don't think it will be practical since I have to park far away from buildings.
Here's some initial research:
I found a picture of the shaft drive unit taken apart. It is a splined shaft that goes to the 2.66:1 differential on the 17" rear wheel.
I'm not overly concerned at this point as to how to couple the motor to this shaft. It would need some type of cardan or u-joint to allow for rear wheel movement.
Batteries:
Since my complete bike has a fairing, I measured about 16" between the openings. The engine itself is about 18" wide at the top. It's hard to measure with an engine in place, but it looks like the frame opening is about 17" high. Front to rear, it's deeper at the rear, but from the bottom to where the frame curves is about 14". I realize this could be squared off to make room for batteries as some have done, but I'd like to avoid cutting the frame. I found a site that allows Calculation of energy stored, current and voltage for a set of batteries in series and parallel. It's educational to play with and see the various results. My plan is to make an enclosure to keep rain out while making it fairly easy to remove and replace the packs.
One thing I have read about are battery scams on China sites such as Aliexpress. While I have bought stuff from there mostly w/o issue, many battery prices are just too good to be true. Even if I got money back, this would eat up a lot of time & cause needless aggravation.
Motor:
According to a formula I read about, I'd need a 75KW motor to equal 100 HP (HP*745/1000). The one on the Sabre project is 88KW and is certainly overkill. It seems like most motors for this type of project involve sprockets and chains, which I want to avoid. The other alternative I've seen is a hub drive, but even though those come in 17" sizes, I have not seen one past 12KW, so I suspect that would be underpowered.
I'd like some advice here as to what volts this should operate at given my goals, or any sources for motors.
Range:
The range formula I found goes like this:
Miles desired / average MPH= # of hours
# Hours * KW used at speed= KWH needed.
I'm not sure this is a valid method, as the faster you go the less KWH you are using, which seems contrary to what I've read about electric motorcycles.
I put in 150 miles @ 60 MPH, which equals 2.5 hours. I have no idea how many KWs are used @ 60 MPH to move about 800 pounds of rider & bike, but put in 10 (or 14 HP) to get a number. This showed I needed a battery capable of 25 KWH. I know the Enerjicas have a battery around this size, but they don't have that kind of highway range.
Using the calculator above, I put in some 3.2V 300 AH batteries I found on Amazon, and with 26 of them this would give me 24.96 KWH @ 77V.
Putting the known Sabre data (36 3.2V 100AH batteries) into the calculator, this gives 115V and 13.8 KWH. Using his claimed 175 miles on the highway (figuring 60 MPH) and the range formula, he's using < 5KW (or about 7 HP) to cruise @ 60 MPH.
Controller:
Still learning. Will decide on this after motor selection. I'd like to add cruise control "while I'm at it".
Recharging:
Still learning.
DC/DC Converter:
Still learning. My BMW has heated grips, so "while I'm at it", I would like to add this as well for colder weather. I know this will affect range.
Batteries:
Motor:
Range:
Controller:
Recharging:
Still learning.
DC/DC Converter:
