Aquakitty
- Joined
- Jun 10, 2017
- Messages
- 179
Hi,
I'm totally new to hub motors but trying to learn so bear with me.
Is it normal to have voltage on the controller after removing the battery? After removing the battery from my DD hub motor install (9C motor style), the controller still has 10 volts. Holding the power button on the LCD seems to discharge this at a slow rate. Is this normal? I ask because I think my phase wires are not in the right order.
Also, is it expected that the DD motor acts like a dynamo when connected to dynamo lights? Because that was happening without the battery connected, just the lights connected to the motor power. Is this some kind of automatic regen happening? I am having trouble Googling info on this for some reason. Also, I'd like to disable the regen if that's what is going on. Here is the controller:
For the record, I believe I have the phase wires in the wrong order as the wheel runs rough and backwards. I thought I would ask these questions before switching up the phase wires.
Edit: Seems this is a Kunteng 12 mofset controller if that wasn't obvious from the pic.
