Doctorbass said:The psu will limit the current. and since the dc-dc can hold more current than the psu will give in serie, the dc-dc will never reach their max current but the psu will
Dont forget that a part of the total current that the psu deliver WILL supply the DC-DC input.. so if you have let say 30A out of the psu, you'll have like 15A in the power supply and 15 for the output..... but the psu wil still see 30A.. so current limiting will be made by the psu.. usually they are power limited.. ( my meanwell RSP 1500 is...) but some are current limited already...
Doc
Nuts&Volts said:LFP,
That is my off board charging planI have the HP 51V57A and 3 IBM 12V48A supplies to try to get a 90V 48A setup. To make sure I understand, Do i have to current limit if I want to charge at full current, 48A? Will the server type power supplies simply blow their tops off if connect say a 75V battery to their ~90V output? (ie they have no current or power limiting)
Doc, I have a RSP-1000 that I am doing this with, do i need to modify it at all to limit current or power? I sounded like the unit was capable of current limiting itself. I have it set to 41-42V out
liveforphysics said:Doctorbass said:The psu will limit the current. and since the dc-dc can hold more current than the psu will give in serie, the dc-dc will never reach their max current but the psu will
Doc
This is not how it works.
The DC/DC's just drop-out if input voltage drops below the minimum threshold. You can not current limit upstream of the DC/DC, it will just turn off and go into 'hicup mode'.
The smart way to charge 24s on a budget is to buy one of these:
http://www.serversupply.com/POWER S...Y/3000WATT REDUNDANT/HP-COMPAQ/253232-001.htm
And stack a couple of these in series with it depending on the voltage you want:
http://www.serversupply.com/MFGR/HP-COMPAQ/POWER SUPPLY/SERVER POWER SUPPLY/575 WATT/335892-001.htm
And then for your current limiting, you need something to top off the stack with that can operate in CC/CV mode, as the other 2 supplies are just CV.
So, you find something like this:
http://cgi.ebay.com/MW-12V-DC-29A-350W-Meanwell-Switching-Power-Supply-/350473428035?pt=LH_DefaultDomain_0&hash=item5199d81c43#ht_5025wt_972
Two of these in series would work well for packs for 24s packs if you wish to charge at 2900w. Or do 4 of them 2p2s to charge at a more manly 5,800watts.
docnjoj said:Hey Dr Bass
Could you do this with a 12 volt power supply to make it 24 volts just using some // D/c-DC 12 volt converters? Would the sam principles apply?
otherDoc
cwah said:I'm trying to understand this chart but I still don't get it:
How come you have 3 DC-DC converter to reach 96V output? I suppose you would need 2 to have 48V*2 = 96V? And what's the grey line connection for?
Thanks![]()
cwah said:So if I understand it correctly, the wiring is:
1) 3*48V DC-DC in parallel to reach 750W
2) The 48V meanwell in series with the 48V750W DC-DC converter. How is it displayed in series? Doesn't look like the wiring in series I used to do with my lipo
3) And why the isolated series step up is connected between the + and - ?
Thanks
cwah said:Thanks Devrie. Much clearer now.
I'm trying to find these module online but they seem to be impossible to find.
Can't see any 12V isolated high current DC-DC converter online?
The one proposed is not sold anymore. Where can I find them?
deVries said:Now, I don't understand how Doctorbass claims his 48v 1500w Meanwell can output 37A, since it can only be 31A with my math at 48v 1500w. IF I am correct, then the maximum you can charge at 96v is 15A. For a higher Meanwell 37A output maybe Doctorbass is thinking 55v (Meanwell maximum voltage setting) + 48v DC/DC output too??? :?![]()
