joshseitz
First-off, I'd like to confirm that it's NOT possible to run a 9-speed freewheel with a MAC geared motor in aluminum 135mm dropouts. If this IS possible, please explain.
Assuming it's not possible and would have to go to 7-speed, do I simply need to change the shifter to 7-speed, and adjust the upper and lower limits on the existing 9-speed derailleur, or do I need a 7-speed specific derailleur as well?
Additionally, can anyone recommend a quality 7-speed shifter (and derailleur, if required)? I generally prefer twist shifters as they can be moved over to the left side easily so as to dedicate my right hand to throttle duties.
