shenzhen_ex
There is an existing industrial process that creates a cooler running motor, improves environmental protection, and upgrades the mechanical strength of electrical motors.
This process is one of the highest industry standards for electric motor encapsulation. The process is called VPI; (Vacuum Pressure Impregnation). This process is only used in a small number of the world’s electric motor production and is primarily applied on extreme heavy duty/ adverse environment applications.
Vacuum pressure impregnation is a process in which vacuum and pressure are used to assist the penetration of liquids into devices. It is often used to impregnate electrical apparatus with resin (we use Loctite Resinol RTC Porosity Sealant). The result is a void free solid where there once were voids at the stator coil windings and stator core laminations.
BENEFITS (cut and paste from some non-confidential documents.)
Strengthens the insulation system and extends service life.
Eliminates the dead air spaces that cause hot spots within coils.
Provides a low thermal resistance path that lowers temperatures.
Creates a repellent to oily substances, moisture, and chemical contaminants.
Resin becomes a sealant against environmental conditions and creates bonds for good mechanical strength.
Reduces mechanical vibrations.
Reduces the audible noise level.
Enhances the dielectric capability, which allows for higher voltage stress levels without failure.
Reduces coil movement.
