spiritxxx733t
100 µW
Hi all,
need some advice please, planning on building my first e bike.. have decided to either buy the crystalyte hs 3540 (from Ebikedeal.com) or bmc v4 speed (from http://www.ebikessf.com)..
im looking for forums users guidance and advice on which set up is better..
I dont plan on over volting or anything like that, primary usage would be commuting to work and shopping errands.. hoping for speeds close to 30 mph or just over this if possible..
I plan on using with a PING 48 volt, either 15 ah or 20 ah, the 20 ah has max discharge of 40 amperage (whatever that means) and the 15 ah has a max discharge of 30 amperage.
( can someone explain max discharge please, thanks).. which battery would you recommend?
what sort of max continuos speed can I hope to get with each motor..
which motor is more reliable,? which is more easier to service?
is the direct drive so hard to pedal without power? is the direct drive much heavier?
what are they like when it comes to mounting a disc rotor to them.. which one is has more spacing and easier to fit a rotor please?
what are your thoughts on the crystalyte apm display and compared to the cycle analyst?
anything else I should know to help me decide..
p.s my commute is mainly flat, but going on shopping errand to the supermarket involves some long hills?
many thanks
many thanks
