Currie back in the kit business
deardancer3
San Diego
A brushed kit with 10h sla 24v pack and rear wheel for $300. (out of stock)
Opinions?
http://www.prurgent.com/2009-08-18/pressrelease50901.htm
Currie Technologies manufactured of Izip and Ezip electric bikes came up with a new version of the famous Currie USPD Pro-Drive system. Amazingly, they were able to keep it at the same low price it was back then but now has many improvements. This new Currie Electro-Drive Conversion Kit easily transforms a standard bicycle and converts it into a modern electric powered ride. The Currie Electric Drive kit can be mounted to nearly any regular bicycle.
The Currie Electro Drive conversion kit is designed to fit on bicycles that use a standard 7-speed freewheels which is quite common today. If the bike that you are planning on converting has something other then a 7-speed freewheels, the kit may still be fitted however we strongly recommend that the conversion be made by an authorized Currie Dealer. A bicycle equipped with this kit will reach a top speed of 18 miles per hour and have a range of 10-20 miles per charge.
Currie Electro Drive features:
• A great price for an entry level kit.
• Easy installation.
• Second battery available to double your range.
The Currie electric bike kit includes
1. Rear Wheel (u use your existing tire and tube).
2. One Battery-pack.
3. Mounting brackets and all required hardware include.
4. Pre-wired Rear battery Rack.
5. Throttle with fuel-gauge.
http://www.izipusa.com/116-currie-electro-drive-conversion-kit-w-plug-play-battery-pack.html
Reg. Price: $ 399.00
You Save:$ 100.00 Temporarily Out of Stock Items Our Price : $ 299.00
Quantity :
Availability : More details about Currie Electro Drive Conversion Kit w/Plug + Play Battery Pack
The Currie Electro Drive conversion kit is designed to fit on bicycles that use a standard 7-speed freewheel which is quite common today. If the bike that you are planning on converting has something other then a 7-speed freewheel, the kit may still be fitted however we strongly recommend that the conversion be made by an authorized Currie Dealer.
This Kit Includes:
1.Rear Wheel (Less Tire/Tube/Freewheel), Brackets and Hardware
2.24V 10AH Battery Pack (One)
3.Rear Rack (Controller Inside)
4.Throttle
5.Battery Charger
6.450W Motor
MOTOR
450W Rated Power from a DC Earth Magnet Motor
BATTERY
EV Rated SLA Type, Rear Rack Mounted, 24V/10AH Pack, (Consisting of two 12V/10AH Valve Regulated, Sealed Leac Acide Rechargeable Batteris in Series)
CHARGE SYSTEM
UL Listed Currie Smart Charger with LED Status Display
CONTROLLER
Exclusive Currie Electro-Drive 24 Volt Fully Potted with Power Guage Function
TOP SPEED
15+ mph/24km (Rider Weight, Rider Input and Terrain Contingent)
RANGE
10 - 15 or More Miles/16 - 24 km with Normal Pedaling (Rider Weight, Rider Input (Pedaling) and Terrain Contingent). Easily Add an Optional Second Battery Pack to Double the Range
DRIVE
Patented Currie Electro-Drive System. Combine with the Drive Train System from your Standard Bike to get Hybrid Power
REAR WHEEL
Alloy 26" x 1.75" Rim: Suitable for Mounting 26 x 1.5" to 26 x 2.2125" Tire, Inner Tube and Rim Strip from your Original Bike; Hub: will Accept 7-Speed Freewheel from your Original Bike; Hub Spacing 135 mm OLN (Standard 7-Speed)
USER CONTROLS
Power On/Off Switch on Back of Rack; Easily Access Charger Port in Removable Battery Pack (Can Charge On or Off the Bike), Twist Thumb Throttle with TAG (Twist and Go) Function & Battery Guage Indicator for Mounting and Handlebar
