Hi, I'm using a Curtis Controller 1236 for several years. Last summer some water got in the motor and i needed to overhaul it. I used this to add a cycle analyst v2 i got lying around.
No after i ride the bike for about 1 minute and use full throttle, the controller stopps. Then i got a overvoltage error at the brake line (pin 17) and a controller overcurrent in the diagnostics. It is a little bit strange as no electrical brake is installed. No wire at pin 17. Furthermore i have no explanation for the over current failure. Next step is to remove the cycle analyst and then the BMS to find the problem.
Any hint which speed up the search is highly appreciated.
Thanks
Thanks
