adrian_sm
My plan is to add a DPST switch that turns off/on the DC-DC converter for my lights and CA backlight at the same time. Luckily both of these require me shorting a couple of pins to turn things off.
From http://www.ebikes.ca/drainbrain.shtml
Has anyone done this. I just cracked up my CA and can't quite work out which pins I should be shorting. I really don't want to just poke around shorting random pins and see what happens.
How do I turn off the backlight?
The backlight can be turned off by shorting the two pins leading to the backlighting LED.
It would be possible to insert a switch across these leads so that you could have ON/OFF control of the light if desired.
