The e-assist installation in my velomobile is a Cyclone motor (with the internal Headline controller), a Cycle Analyst v3 driving the motor's throttle-in line, and a 24V battery.
The CA receives its inputs from a regular 5V hall effect throttle, a speedo pickup (reed switch) on the rear wheel, and a shunt on the power line. There's also a Cycle Analogger connected to the CA.
Up to now it was all working fine. But I've been having this weird problem for the past few days: every now and then, my motor cuts out for a split second. For instance, I'm at full throttle, the motor stops for half a second, then restarts. It restarts on its own, I don't have let go of the throttle or anything.
It seems to happen more when I'm accelerating, and/or at low speed, but not always: sometimes it cuts out in the middle of a long ride at full throttle.
At first, I thought it was the motor's internal thermal protection, but it can also happen when the motor is cold. So I took a look at the data log in my Cycle Analogger, and it turns out the culprit is the CA: when the problem occurs, the CA seems to drop the ThO signal temporarily. Additionally, while the motor is off, the CA seems to be totally confused with the bike's speed. When the motor restarts, everything goes back to normal.
Check out this video, in which I display the Analogger's data in real time. The problem occurs at 00:29:
http://www.dailymotion.com/video/x4cfkhz
Anybody knows what might be going on with my CA?
