Can someone confirm if this Output power jack has 2.1 ou 2.5mm center pin ?
sorg 1 mW Joined Apr 29, 2018 Messages 18 Mar 15, 2025 #1 Can someone confirm if this Output power jack has 2.1 ou 2.5mm center pin ?
E-HP 1 TW Joined Nov 1, 2018 Messages 8,386 Location USA Mar 15, 2025 #2 sorg said: Can someone confirm if this Output power jack has 2.1 ou 2.5mm center pin ? Click to expand... Did you mean to type 5.5mm x 2.1mm? Last edited: Mar 15, 2025
sorg 1 mW Joined Apr 29, 2018 Messages 18 Mar 15, 2025 #3 I know that the outside diameter of the barrel is 5.5mm. For the center pin there are two different standard : 2.1 and 2.5mm. I want to know which standard is used by the CA.
