Cycle Luminator/motorcycle headlamp retrofit
Hudson, New Hampshire USA
I retrofit a cycle luminator into a 5.75" motorcycle single round headlamp. For those of you who dont know, the cycle luminator is a 1000 lumen led light that works with voltages up to 100v. It is made by grin cyclery and plugs directly into the cycle analyst v3.
I wanted a very bright light, but I also wanted to retain a vintage, boardtrack inspired look.
I considered an hid but decided against it because of heat and power consumption. Plus the cycle luminator plugs directly into my cycle analyst.
I even picked up a splitter cord and extension cable to run an electrolight tail light, which grin cyclery also sells. No soldering, no splicing....just some custom fabbing on the front headlamp.
Ill post some pics of the light output later.
Good job man!
Very clean looking retrofit. This could pave the way for some cheaper iterations using the same idea. I like it.
