Domhelp said:Thanks for the info. I have never ordered anything from aliexpress. Is it easy and reliable to buy a battery from there?
Yes it is pretty straightforward, as long as you deal with a reputable seller.
Domhelp said:Mild day so I decided to try it out. Very happy no problems. Motor mount is solid I don't anticipate flexing issues.
Throttle is jumpy and sensitive need to get used to it. Is it adjustable?
Domhelp said:Got a cycle analyst now have to wait for good weather to really test the battery. I'm drawing 40 amps at full throttle and voltage about 80v underload with a fresh battery so thats about 3000w. Totally gutless compared to my dual sport motorcycle but I can't ride that where I will be riding this. That why I built it...for some urban fookery :lol: :lol:
Tommm said:Domhelp said:Got a cycle analyst now have to wait for good weather to really test the battery. I'm drawing 40 amps at full throttle and voltage about 80v underload with a fresh battery so thats about 3000w. Totally gutless compared to my dual sport motorcycle but I can't ride that where I will be riding this. That why I built it...for some urban fookery :lol: :lol:
If your battery allows it, shunt the controller to around 60a, it will be stronger than your moto.
Domhelp said:Tommm said:Domhelp said:Got a cycle analyst now have to wait for good weather to really test the battery. I'm drawing 40 amps at full throttle and voltage about 80v underload with a fresh battery so thats about 3000w. Totally gutless compared to my dual sport motorcycle but I can't ride that where I will be riding this. That why I built it...for some urban fookery :lol: :lol:
I'm happy with it. I guess I'm getting old. Don't want the breakdowns.
crossbreak said:why do u buy such crab if u assume that? i dont want a 7 year old to do anything but play (and maybe eat, sleep...) get balls and make it by yourself, all the knowlage you need is spread here :wink:
Domhelp said:My drive chain has been fine. My rear cassette chain broke. Luckily I was close to home. It was my fault I think. I lengthened it by a few links and I think it separated where I joined the extra links. Once you pop out a pin then press it back in, that pin will become a weak spot. I think if I buy a new chain and leave it or use master links to add links I should be fine. It a good idea to carry a spare chain or at least a chain link tool to mend a broken chain.
Tommm said:Domhelp said:My drive chain has been fine. My rear cassette chain broke. Luckily I was close to home. It was my fault I think. I lengthened it by a few links and I think it separated where I joined the extra links. Once you pop out a pin then press it back in, that pin will become a weak spot. I think if I buy a new chain and leave it or use master links to add links I should be fine. It a good idea to carry a spare chain or at least a chain link tool to mend a broken chain.
Only way to get around it is to buy a chain bigger than you need and have a missing/master link to join it after shortening it. So far the special link isn't a weak spot.
If you edit the chain you are foked, and it will mess up your cogs too.
Domhelp said:I noticed that when I lengthened my chain my tallest gear would slip at high speed. Curious as to why my cassette will get damaged if I lengthened my chain? I though it was skipping because it was now too loose.
Makes sense thanks.Tommm said:Domhelp said:I noticed that when I lengthened my chain my tallest gear would slip at high speed. Curious as to why my cassette will get damaged if I lengthened my chain? I though it was skipping because it was now too loose.
The longer you used a stretched/bad condition chain and the smaller the gear on the cassette, the more likely the new chain will skip. If you lengthen a chain from new links, those links will have a high chance of skipping.
Domhelp said:For high top speeds or high wattage a hub motor is better. Only if you need lots of torque off the line will you benefit from a mid drive. I like my mid drive, the fun factor is high, but I expect it to be less reliable then my hub drive
bakaneko said:Domhelp said:For high top speeds or high wattage a hub motor is better. Only if you need lots of torque off the line will you benefit from a mid drive. I like my mid drive, the fun factor is high, but I expect it to be less reliable then my hub drive
I agree. I think a mid drive really benefits for trail riding or mountain biking where the leverage torque from gears helps and weight distribution is ideal. But, I am leaning towards hub drive for a daily hassle free commute. My problem was that my batteries are either in a 36V or 72V configuration and all the reasonably priced high power (1.5-2kw) hub motors were for 48V systems and I didn't want to monkey around with a new controller connections and compatibility and also lose any LCD/LED displays from the kit.
I kinda hesitate on the torque off the line. I feel like I am going to snap my chain. That is probably where the synergy from the hub motor and rider works, since the hub is single gear as a rider you can put it in a low gear and really help it off the line and not worry about snapping the chain from the power of the motor. Maybe, this is just a grass is greener thing and with more distance riding in the summer I might change my mind. Also, the other plus of the mid drive is that you can actually pedal the thing with little cogging or resistance.
Domhelp said:Makes sense thanks.
I am going start over with a new chain. I am going to avoid the smallest gears as I don't really need them and they will really load and stretch the chain. I have come to the conclusion that if you are only going to have one electric bike then a hub motor is the way to go. For high top speeds or high wattage a hub motor is better. Only if you need lots of torque off the line will you benefit from a mid drive. I like my mid drive, the fun factor is high, but I expect it to be less reliable then my hub drive
