pickworthi
Established
I have a DALY Smart BMS (10S). It is functioning correctly, in that I have it connected to a 10S pack, and it is displaying the cell voltages in the PC application (UART connection) correctly. Also, charge and discharge are fine.
My issue is that I want to change the cell low voltage cut off, and cell maximum voltage. The application offers "set" options for these, but does not set them when told to do so - i.e. factory settings are still there when refreshed.
There are two PC applications. The one that is displaying things correctly is called "PC Master".
There is another application that has a Chinese only setup process, and displays an IC list to choose from when started. I've selected all the IC values presented, but in this application no data is displayed.
I suspect there is some magic hidden setting that is stopping things from being changed, but I can't find it :-(
I though I'd start with a short post to see if anyone here has managed to change any settings on a DALY smart BMS.
