recumpence
1 GW
Hey Guys,
What you are looking at is the culmination of over a year of planning (in my head), hundreds of hours of design time, and production cost in the 5 digits.
This is my newest drive. I am calling it the DaVinci drive due to its somewhat artistic appearance.
The foundation of this drive is the motor cradle and carriage. These two parts are machined from 1.5 inch 6061 plate. The motor slides through the cradle, which clamps to the motor can. This sinks heat from the motor directly into the drive unit. Belt tension is accomplished by one simple screw that pushes on the curved tab in the curved slot. That screw (accessable from the top of the drive) is simply turned clockwise to add belt tension. SUPER simple. This drive is EXTREMELY rigid and strong. The improvements over my standard V4 drive are as follows;
-Stiffer for better belt tracking
-Quieter due to the can being wrapped in the cradle and the increased rigidity of the drive itself.
-Super simple belt adjustability
-Easier service (if ever required)
-Lower Q factor (1/2 inch narrower than my V4 drive)
-More efficient (this drive arrangement eliminates the cantelever bearing on the V4, thus reducing drag)
-FAR better heat dissipation
-More power from the motor. This is due to being able to run the motor harder from the improved cooling. This should allow the user to run one size smaller motor with the same output power, or at least close to it.
-Greater power handling from the belt due to more rigidity and greater belt tension possibility
-Greater flexibility in mounting due to the offset mount foot. This foot can be mounted forward or backward, thus allowing more mounting options.
Bear in mind, this new drive is not replacing the V4. It is in addition to it. The V4 is still a good option for many applications especially where cost is concerned. However, the added cost of this new drive would be offset if the customer purchased heat sinks. So, my V4 plus 3 heatsinks (for a 3220), is very close to the cost of the DaVinci drive.
This drive was developed for a number of reasons (all of which I cannot get into here). The main reason is maximizing performance as well as useability, reliability, and adjsutability. Besides, a little Bling is not a bad thing. :wink:
I am looking into laser engraving for the DaVinci name on the drive.
We are puting the finishing touches on the first run of these drives. I am out of motor pullies right now and I need shims and other bits. But, the drives will be ready for sale within a couple weeks. Oh, I also have 3 Astro motors in stock as well if anyone wants one.
Lastly, this drive will be available in 4 to 1 or 5 to 1 ratio with the torque limiter.
The drive is $575.
I know it is not for everyone. But, I think, for the truely performance minded builders, this drive is the best way to go.
Matt
The drive is $575.
Matt
