I recall that when the e-max electric scooter venture was going south due to prematurely failing "silicone" batteries and failing chargers on every scooter delivered, they kept promising a miracle charger that would fix the problems. They want out of business altogether before any of these chargers materialized.
Later, I finally got one of these chargers from an owner of what was the same generic Chinese e-scooter being sold under a different name. The charger has a very odd protocol. On at 15 amps or more for about 5 seconds, off for 5 seconds, repeating through the CC cycle, with occasional longer pauses, The CV cycle was similar, but decreasing current of course.
It seems this is where they got the idea from.
Unfortunately, true to it's Chinese origins the charger failed after only a dozen uses - probably failure of the programmable microprocessor chip that ran the protocol. So I was unable to see if there was any benefit to either of my scooters both have 300 to 400 cycles and are down to only 50-60% or the new capacity.
At any rate, SLA's still suffer from their very poor energy density. Their sheer weight limits the range any kind of EV using them could have. And 700 cycles still doesn't cut it.
AS far as lithium being cost competitive with lead, they already are. An SLA pack for my scooters is up to $700. A LiFePO4 pack is $1400 to $1600, but will last even pessimistically, 3-4 times longer.
