I don't know why I torture myself so over batteries, but this time I decided to try a DeWalt 28v build since they were so cheap from toolking.com. The lesson learned here (again) is that what you think you're going to do uber-cheap ends up costing you tons of money so you might as well just buy a frickin' pre-built headway or ping or cell_man these days. This lesson will sink in someday I swear. :x
Anyway.. 2s4p in packs and I wanted to use the existing flashlight's circuitry to protect the packs. Well.. all seemed to be going well during the build, but this afternoon I fired it all up and things were not as they seemed. I was reading around 53v, which seemed a little low though the batts had been resting a few days so maybe that's nominal/normal around 3.3v. As I was doing final tinkering I watched as the voltage crept down and down until it was around 51.2v when I actually hopped on to ride. I floored it and the voltage sagged loooooow down to the low 30s... hmm... that's not right.
My conclusion at this point is that somehow, despite my direct wiring, I'm only "seeing" 2s1p at the controller, which would explain the voltage sag. But.. when I removed all the batts one battery was still 29.2v and a few were at 27.7-28v so I think it's a connection/wiring issue I need to deal with first and then maybe bypass the flashlight circuitry and try again.
I also notice that I'm reading 3.5-4v even with all the flashlights "off" so there is some sort of parasitic drain from the flashlights.
What a bummer and a waste of money. Back to the drawing board for now.
