dogman dan
1 PW
You are on the right track. The load tester you used may not be giving it anywhere near the load the bike does. So it's possible it passes that test, but fails a heavier load. Under load, the battery may be sagging enough to engage the lvc of the controller.
Now that I get it that the bike has a replacement controller, I would make a bet that the controller is too strong for any sla pack of the size you have. It's just so common, go buy a huge controller, wreck your battery. Your controller may have a very high low voltage cutoff setting, perhaps it's not the right voltage controller for your 5 battery pack. Lots of possibilities.
Furthermore, now I suspect everything, suspect plugs and wires even more than when stock. But do go through the wiring as soon as you have some free time to squander. It could easily be an intermittent bad connection to the battery pack, often at the fuse. Holds power for 5 amps, but roll back the throttle for more and it goes dead.
Those are the ones that are so hard to track down, not the obviously screwed melted plug, but the one that looks good but isn't.
