sviatpizdat
- Joined
- Aug 19, 2020
- Messages
- 27
Hello everyone!
The outer shaft of my Cyclone 1680W motor developed a little play. The internals of the gearbox seems to be good - no teeth wear, no play in the satellite bearings. I think the bearings of the outer drive shaft may be worn out. And I need to replace them.
Does anyone know how to disassemble this part? - to remove seal and shaft, and then bearings?
I tried to disassemble it but failed. The bolts of planetary assembly cannot be removed - I bent a hex key.
But probably I don't need to disassemble planetary assembly at all. There are pictures over the internet of the whole planetary assembly disassembled.
I guess the outer planetary cage plate and the shaft are one-piece, and maybe I can just press or hammer everything from the 'outside' to the 'inside' of the gearbox, and the whole assembly + shaft will come out.
