I have a 5kW DC load that works awesome for that, but when I don't have it around, I use strips of stainless steel, bend them into a 'U' shape, put oven mits (or kevlar glass blower mits) on and short it across the terminals. Remove bar before it's glowing unless you're into wearing flaming mits and enjoy blisters.
AISI Type 304 Stainless Steel
Physical Properties Metric English
Electrical Properties
Electrical Resistivity 7.2e-005 ohm-cm 7.2e-005 ohm-cm
It's easy to calculate whatever load you need this way by the length and cross section of the strip. If you like to bleed large cells down rapidly, I recommend a 1/2" * 1/8" thick 304 stainless strip 6ft long bent in a U-shape so you can smash it against the terminals.
