The wear pattern probably was shifted due to forgotten metal flake in 16003 bearing bore by the factory.
Lost the metal flake due to having to sort out other things so can’t confirm the thickness of metal flake.
Will this result in improper gear mesh with proper 16003 bearing position?
Judging by the pictures the wear pattern should be slightly closer to the inner edge of the teeth.
Don’t feel like ordering a second ring gear and pinion gear.
Using slightly thicker ring gear cover gasket might compensate for this but it will be hard to find proper thickness.
My pinion gear is on the right side.
