vax
Hello folks, I wanted to share you my affordable wind turbine project.
Technical part:
Velectris Phsntom hub motor (tested with 20A continuous, didnt get even warm).
3x pcs of chinese 85cm grp blades
http://www.ebay.com/itm/85cm-length-300-1000W-Wind-turbine-blade-Price-high-quality-for-sale-MOQ-3-/251986176400?pt=LH_DefaultDomain_0&hash=item3aab8be990
Laser cut 6mm aluminium adapter plates (drawings available if needed),
20mm MTB through axle hub with dual disc mounts - ideal for vertical axis.
Plywood tail.
[youtube]JRLXElg_Sac[/youtube]
Technical part:
Plywood tail.
