Doctorbass
Here is the link: http://electricmotorcycleforum.com/boards/index.php?topic=3085.0
Here is some interesting data:
TESTED results
11 august 2013)
Efficiency measured: 92.5% ( 6980W AC 6460W DC out)
Current consumption ( at max output power): 30.5A AC
Max power output ( mean at end of charge) 6.60kW
Voltage output: 74.0V ( adjustable from 29 to 76.8VDC)
Current output: 91A (0.75C charging rate)
Weight ( including connectors and harness): 13.4lbs
Dimensions: L 13.2" x W 5" x D 5"
Max temp ( case): 43 celsius
Zero ZF9 battery temp at end of charge ( internal OEM temp sensor): 32 celsius
Zero ZF9 Battery measured capacity (with 2 bar flashing on the gauge): 6600Wh
[youtube]zrKQ12GJSLs[/youtube]
Some pictures for you guys:
( The update of my AC electrical network in my garage ( my 60A 240V sub pannel and the 40A 240V plug for charging my zero!)
Some picture of teh cahrger and also comparing the size of the original zero 1kW charger)
and finally the Cycle Analyst i installed on it and showing the reverse current charging the battery at 90Amp ! and 6.6kW
Doc
TESTED results
Doc
